SUN MCS2000 SL - engine tester with HxC emulator
tomsail
Post by tomsail »
another mcs 2000 sl is back to life!
it was build in 1992 and was "upgraded" until 1998 with diesel smoke control and other "goodies".
dumping the copy-protected non-IBM-floppies with the HxC software was (thanks to this forum) quite easy.
I had a stock of about 15 different discs 7, of them with bad sectors. :-(
but I managed to dump the V552 system disc and the v552 AU-2 disc to .hfe files.
this ist a matching late twin-disc version enabling the MCS2000It to test 3-12cyl. engines with free programs or test the lambda control system for german exhaust emission control test.
HxC emulator was set to "Emu Shugart", sound to maximum, lights and device "on".
see: SUN MCS2000 SL
Or
SUN MCS2000 SL
regards
thomas
emilia2000
Re: SUN MCS2000 SL - engine tester with HxC emulator
Post by emilia2000 »
Hi!
I've got that machine (SUN MCS2000 SL) and my floppy disks are broken.I would like to use emulator but I dont have soft to this machine.Can somebody help me?
Thanks,Robert.
emilia2000 wrote:Hi!
Thanks,Robert.
I think that i have a deutsch & israelian version... Not sure if this interest you.
emilia2000
Hi,deutsch version would be great..if you need my email milia80@tlen.pl
Thank for your help I'm really grateful.
meatmaschin86
Post by meatmaschin86 »
Hi, can you send the Deutsche Version to me? My Disk´s are broken too!
My e-mail is hanspetergrafl@gmx.at
Thank you very much!!
siavash
Post by siavash »
Can you please email me the file as well. Thanks in advanced
SJ@TheBridgeCorporate.com
siavash
Post by siavash »
I have also a sun mcs2000 and my floppies do not response
and I need the files . of course the german version is quite good for me .
sj@thebridgecorporate.com
siavash wrote:I have also a sun mcs2000 and my floppies do not response
Not sure that the file will help you without the HxC hardware :
The MCS2000 floppies use some copy protection stuff in their format, and this can not be write back to disk with normal/standard hardware.
siavash
Post by siavash »
Thank you for the reply. If I get the files then of course I will begin to buy the HxC hardware.
siavash
Post by siavash »
Hi , I need one HxC emulator and the files for running
my sun mcs2000sl .Please tell me what should I do?
siavash
Post by siavash »
I have not received a clear answer yet. As I told I have a SUN MCS 2000 with many faulty floppies. Please help me to solve my problem.How can I have an Hxc emulator and the files for my SUN MCS 2000?
Thanks a lot.
bzsun
Post by bzsun »
Hi , I have sun mcs 2000 from Opel service. Can you send me floppy image because i have floppy from 1994 and it don't work. My e-mail is amadeusz.klupak@gmail.com.
How can i get image from my floppy and record this on sd card ?
Sorry for my bad english because i'm from Poland.
Ok so since this seems to be an serious issue with these machines, please contact me by email.
We have a dump/copy service.
Just send me the disk to France and you will have the image (if the disk is in good condition).
bzsun
Post by bzsun »
Is it possible to do it at home ?
I have 6 disks. How can i read the floppy on PC and record this on SD card ?
bzsun wrote:Is it possible to do it at home ?
Yes : Read this thread :
https://hxc2001.com/floppy/forum/viewtopic.php?f=2&t=865
And the page 14 of this :
But don't forget to share your files ;)
