Stuck trying to install GOTEK USB into MIRAGE
Matt
Post by Matt »
Hello, i am a newbie and i'm trying to install a gotek usb into my Mirage with no success so far. Is there a guide somewhere?
i have a SFR1M44-U100K-R and i followed this https://hxc2001.com/docs/gotek-floppy-e ... ion-straps artery way till the end succesfully and i validate the firmware. Then i formatted the usb and the files i have into it are : DSKA0000.hfe, EXCHANGE.BIN, HxCFEUSB_V3_8_3_1a.UPD, os32.EDM and a folder with a library. Now i'm stucked, i turn on the Mirage and nothing happens in both mirage and gotek display.
any help would be very very appreciated
thanks a lot
Matt
Re: Stuck trying to install GOTEK USB into MIRAGE
Post by Matt »
Ok i made a step forward, now the mirage shows 21 on the display but the gotek display is blank. the firmware HxCFEUSB_V3_8_3_1a is in the usb stick and the exchange.bin file as well. any hel would be awesome. thanks
You should use the HxCFEUSB_V4_2_8_4a.UPD firmware.
Please update :
