Does GoTek support copy-protected HFE images?
keenerb
Re: Does GoTek support copy-protected HFE images?
Post by keenerb »
I tried a handful of games. They all seem to boot fine from plain hfe disk conversions. That special a2dd format is unrecognized by the trackstar.
Unfortunately you were correct: the disks are all read only. I hope that can be fixed at some point...
keenerb
Post by keenerb »
I feel like writes SHOULD work in this situation, the Trackstar actually interfaces the 360kb PC floppy drive directly with a special cable splitter. I don't think any special apple 2 support is really NEEDED here.
Maybe the disk image I'm using has issues. I am going to try some more later. Getting write access to these apple II disks would be tremendous for me.
keenerb wrote: Sun Feb 23, 2020 1:21 am I feel like writes SHOULD work in this situation, the Trackstar actually interfaces the 360kb PC floppy drive directly with a special cable splitter. I don't think any special apple 2 support is really NEEDED here.
The firmware is checking the sector validity, so it must understand the incoming data. I will add an option to disable this checking in a next version. And i must check if the firmware can deal with the 12uS pulses spacing. It should, but i am currently not sure since this wasn't tested yet.
keenerb
Post by keenerb »
Interesting, thanks.
keenerb
Post by keenerb »
Is there a way to keep track of firmware changes other than the beta notes on the main download page?
keenerb wrote: Mon Mar 02, 2020 3:22 pm Is there a way to keep track of firmware changes other than the beta notes on the main download page?
On this thread ? :
viewtopic.php?f=33&t=3147&p=22297#p22297
keenerb
Post by keenerb »
Yep that's what I was looking for!
keenerb
Post by keenerb »
viewtopic.php?t=1177
Is it a reasonably safe assumption that whatever eventually fixes disk writes on HDDD a2-connected gotek will also fix writes in my scenario?
keenerb wrote: Fri Mar 06, 2020 6:26 pm viewtopic.php?t=1177
No. i need to "implement" a transparent mode.
keenerb
Post by keenerb »
OK, that's good to know. I"ll keep a hopeful eye on the updates thread :)
keenerb wrote: Tue Mar 10, 2020 6:06 pm OK, that's good to know. I"ll keep a hopeful eye on the updates thread :)
Got some minutes to add the needed flags for the GCR Apple II write support and to make some basic tests :
To get the firmware : https://hxc2001.com/custom_fw/
Set the "HFE blind write mode support (don't check/ignore sync words)" and "GCR encoding method write mode support" checkboxes and set "Read emulation pipeline buffer size" to "short".
This should enable the write support for you.
keenerb
Post by keenerb »
Magic Candle seems to save but there's nothing listed when I restore, and Telengard returns some "error 6" when saving using the firmware you provided to me earlier.
I'll go through the custom firmware portal and build a different one in case something's wrong.
keenerb
Post by keenerb »
I built custom firmware with the options you mentioned and still not saving so not sure what's up.
keenerb wrote: Mon May 04, 2020 9:35 pm I built custom firmware with the options you mentioned and still not saving so not sure what's up.
Are you sure you have updated the firmware ? (Please check the version number on the gotek)
Also please send me the hfe before and after the write attempt.
keenerb
Post by keenerb »
(c) HxC2001
v3.4.15.1a
Image names should be self-explanatory.
Pre-write is before anythign written, afterwrite is after a write attempt (game save).
images.zip
(240.34 KiB) Downloaded 1517 times
