Does GoTek support copy-protected HFE images?
keenerb
Post by keenerb »
HxCFEUSB_V3_4_10_10a firmware version.
I've downloaded the Trackstar 128 utility disk kyroflux image from:
https://www.diskman.com/presents/tracks ... m_disk.zip
I've loaded that image into HxCFloppyEmulator 2.2.3.1 and then exported to HFE, HFE Stream, HFE V3 formats and copied to a USB stick as disk 3 in INDEXED mode.
Boot disk 0 works, empty disk 1 works, empty disk 2 works, but the copy protected disk 3 reports "Not ready error reading drive B".
Occasionally it will allow "dir" command to list the five files on the disk image before reporting "Not ready error reading drive B", but I'm still unable to execute the files.
Re: Does GoTek support copy-protected HFE images?
Yes it does, but where is the disk 3 ??
keenerb
Post by keenerb »
Sorry I meant I have three disk images on the USB key inserted into my hxc gotek. One is a generic boot disk, one is an empty disk, and dska0003.hfe is the 360kb trackstar utility disk.
keenerb wrote: Sat Feb 15, 2020 12:22 am Sorry I meant I have three disk images on the USB key inserted into my hxc gotek. One is a generic boot disk, one is an empty disk, and dska0003.hfe is the 360kb trackstar utility disk.
Is it normal to have some Apple II tracks on this ISO MFM floppy disk ?
keenerb
Post by keenerb »
Probably. It is an apple emulator for xt computers so it wouldnt surprise me.
keenerb
Post by keenerb »
Didn't have any more luck with this today. SHOULD this be working, or is there something tricky about this copy protection?
keenerb wrote: Sun Feb 16, 2020 3:08 am Didn't have any more luck with this today. SHOULD this be working, or is there something tricky about this copy protection?
This should works but there is an issue with the hxc stream analyser with Apple II gcr tracks. This need to be fixed to properly convert them to hfe.
keenerb
Post by keenerb »
Excellent, thanks. Does this bug apply to other apple disk conversions?
keenerb wrote: Sun Feb 16, 2020 4:39 pm Excellent, thanks. Does this bug apply to other apple disk conversions?
No, only to stream based imports (SCP, Kryoflux, Pauline/HxC Stream...)
keenerb
Post by keenerb »
No luck. Still get errors on my HXC gotek.
keenerb wrote: Wed Feb 19, 2020 2:47 am No luck. Still get errors on my HXC gotek.
At which track ?
keenerb
Post by keenerb »
I'm not sure how I can tell. WHen I switch to that image I simply get abort/retry/fail errors even for "dir *.*"
keenerb
Post by keenerb »
7 segments screen : display track position
Should I turn that on and get a custom firmware?
keenerb wrote: Wed Feb 19, 2020 8:44 pm 7 segments screen : display track position
yes if you don't have any oled/lcd.
