Akai S3000
Liam_79
Akai S3000
Post by Liam_79 »
Hi all,
I've been trying to get a Revision F HxC to work with an Akai S3000. I'm so close to getting it to function but I'm sure there's something in the settings I'm not doing right.
I made an image of the original Akai sounds disk with omniflop, and then transferred it to the SD card following all the settings that are suggested in a post below for the Akai S20. I assumed the S20 was of a similar age and must use a virtually identical disk system.
The S3000 "sees" the samples and programs (they're displayed on the Akai's screen) but can't load them, all you get is a brief click from the drive and then the sampler becomes unresponsive. Power off is the only remedy.
I do realise that the Akai S3000 is listed by Lotharek in the "should work" category rather than tested and working, but I took a chance as other Akais appeared to work successfully with the virtual drive.
Would be marvellous to get this up and running, 8 outputs and effects with 4gb of samples on one card is quite a decent hardware drum machine. Any help would be much appreciated :D
Re: Akai S3000
Can you send me the HFE that you are using ?
Can you do a S3000 disk dump with the hxc software and send me the hfe file ?
What is your jumper setting ?
Liam_79
Re: Akai S3000
Post by Liam_79 »
Thanks for the quick reply, how exactly do I send the files to you? I tried to send an email but it was returned. Do excuse me, I'm still quite new around here.
By the way, I'm using one jumper on ID0, just in case that could be an issue.
Re: Akai S3000
Liam_79
Re: Akai S3000
Post by Liam_79 »
Typed the email address incorrectly, thanks. Should be sent ok now.
Re: Akai S3000
I just send to you an hfe to test.
Liam_79
Re: Akai S3000
Post by Liam_79 »
Just thought I'd confirm that the Hxc works fine in the S2000 and S3000 samplers with no mods providing that the emulator is set to Akai S950 HD mode on the unit, not on the .cfg file.
Re: Akai S3000
Liam_79 wrote:Just thought I'd confirm that the Hxc works fine in the S2000 and S3000 samplers with no mods providing that the emulator is set to Akai S950 HD mode on the unit, not on the .cfg file.
Thanks for the feedback!
Any details about the switches setting ? Some disk image to share ? Some pictures ? a video maybe ? ;)
Reggertron
Re: Akai S3000
Post by Reggertron »
Hi all. My first post. I am really at a loss now. Successfully hxc'd my gotek emulator. But cant seem to get any joy from the thing.
I am using s950 image.
Not sure how to change the settings of the emulator for my own bidding.
Please help i am at the end of my tether :x :x
