I have a old Yamaha PSR 2700. The Diskdrive is dead. Is there a chance to replace the old diskdrive with a HxC SD?
The old diskdrive used old DD diskettes, and another problem is it has no 34pin floppy cable but a "flatcable" (I can take some pictures of it if it helps)
Any experiences with that Keyboard?
Thank you very much.
Any experiences with Yamaha PSR 2700 ?
Re: Any experiences with Yamaha PSR 2700 ?
If you have a flatcable converter, this should work without problem.Retrofoxy wrote:I have a old Yamaha PSR 2700. The Diskdrive is dead. Is there a chance to replace the old diskdrive with a HxC SD?
Thank you for your answer. unfortunately I can't find a flatcable converter. The Keyboard uses a 24 pin flatcable. I attached a picture. Yamaha sent me a shematics of the FDD connetctor, but I can't figure out how I can build a convertor out of it. Any help? Thank you.
- PSR1700-2700_OA1 Floppyanschluss.jpg (158.8 KiB) Viewed 8857 times
- P1020612.jpg (143.7 KiB) Viewed 8857 times
Ok I am really stuck here. Can anyone help me with a adapter there? I even can't find a "24 pin flat cable connector". Are the parts not produced anymore ?
Any ideas if there is a way to fit the HxC in a PSR 2700?
Do you know how to solder ?Retrofoxy wrote:Ok I am really stuck here. Can anyone help me with a adapter there? I even can't find a "24 pin flat cable connector". Are the parts not produced anymore ?
a little bit, yes, as long as it does not include any SMD parts
