I order from Lotharek 3 PCB + Pic. At work, a good friend complete assembly.
At home, I test the board with an old Atari 520 STe.
I already own an Rev B, which work perfectly (just to be sure the computer work, and SD card is Ok).
When I plug the new rev C into the computer, it doesn't power on (no led on on the computer nor on the HxC)!
I will investigate it with the schematic and scope, but if somebody has an idea why the card prevent power on, it's welcome
Edit : Even if this first card is complete, I did not use LCD, since connector is not solder, since I don't already know if i will use a cable or plug it directly.
Is it required ?
Regards,
Christophe
