firmware: scrolling suggestion
_cc_
Post by _cc_ »
Jean-Francois,
I hope this is the right place to post my suggestion:
I'd be happy if the previous and next buttons would allow to scroll through the files and NOT stop at the last or first file but instead scroll further:
when reaching the last file it should jump to the first and re-begin scrolling there.
The best would be to scroll this way:
scrolling up: first, 2, 3, 4, 5, .....n..., last, wait half a second, (peep), first, 2, 3, 4.....
scrolling down: n, ..., 4, 3, 2, 1, wait half a second, (peep), last, ...n, 4,3, 2, and so on.
This would make things easier for me :-)) I have many files on the sd card and re-beginning with the first one often takes some time. And leaving a directory would be also easier, if the ".." would appear before the first and after the last file.
What do you think?
Thank you + best wishes
Claudio
skideric
Re: firmware: scrolling suggestion
Post by skideric »
I tend to agree. It would be a MAJOR improvement.
Thanks for bringing this up. :wink:
Amiga 500 x2,Action Replay II,A600,A1200 x2(1-030,32MB,Squirrel),A2000,CD32,C128 x3,C128D x2,C64 x5,Com SX64,Com +4,A-30XE,Ti994A x2,T-Sinclair x2,Vic20 x2,TG16,Turbo Duo,CoCo 2,Micro CoCo,AII-GS,AIIe,Jaguar,3DO x2,Virtual Boy x2,C64 AIO x5,A-7800,PONG!
skideric wrote:I tend to agree. It would be a MAJOR improvement.
An alpha version :
https://hxc2001.com/floppy_drive_emulat ... e_beta.zip
:wink:
_cc_
Post by _cc_ »
wow! that was fast! already installing...
_cc_
Post by _cc_ »
new firmware came just like ordered :)
I need some more testing, but up to now it looks just fine.
THANKS!
Best regards
Claudio
fresh
Post by fresh »
hi,
this scrolling option works with all supported machine like e-mu sp 1200 ?
fresh wrote:hi,
Yes of course!
This is only a User interface change!
