Which Gotek to purchase for MC50 MKII
MKB
Post by MKB »
Hello all, first post here. Which Gotek should I buy for using the HxC firmware with a MC50 MKII? I also have a MC50 MKI and was able to get the Gotek SFRM72-TU100K working out of the box with a simple jumper change (no HxC firmware on it). But this drive did not work in the MKII. This makes me a bit nervous about just buying a drive from the HxC compatibility list.
If I understand correctly, the list of Gotek drives will all work with all MC50's if the HxC firmware is loaded and correctly configured on the Gotek. Is this correct?
I also checked on the compatibility list, and there is an entry for the MC50 MKII on the list with a link to a forum post, but the link on the forum post opens a web page saying "nothing here". So no help there.
I just need a tested compatible Gotek USB FDD emulator part number, and will then purchase HxC to install on it.
Thanks for all your help!
Re: Which Gotek to purchase for MC50 MKII
My recommendation is just to take any gotek and reflash it.
You can reflash your current SFRM72-TU100K with the hxc firmware :
https://hxc2001.com/docs/gotek-floppy-e ... ation.html
You can get back the missing page there :
https://web.archive.org/web/20150310092 ... 0.html#HXC
And indeed, as presented on this page, you can also get a true SD HxC Floppy Emulator, already flashed and working :
https://lotharek.pl/productdetail.php?id=27
MKB
Post by MKB »
Thanks Jeff for the reply, much appreciated!!
