HCX2001 on a Kaypro 4
jrdurgan
Post by jrdurgan »
I am a very new user. I just acquired this Kaypro 4. The floppy emulator was already installed when. I got the unit. It seems to work fine. When I powered it up it booted fine. If I do a DIR command I can see all the files on the currently installed A drive image. I have successfully done a copy to create a formatted disk on. the b drive. So far so good. I can see what is on the SD card by pushing the forward and back buttons. The previous owner used a rather different naming convention for his disk images. There are several on the Sa card. When I use forward or back to get to a disk image, and press the center button to load it. the lcd window show that image as active. The question is, how can I see what files are on the disk image. The DIR command doesn't work. Another question is, when I power off and then power on, the a drive has what ever the last disk image was that was selected, and not the boot disk image. Is that the way this is supposed to work. I have downloaded all the user manuals and the software necessary to create software from the archives. Final Question can I rename the disk images to something that reflects what software is actually on the disk.
Thanks in advance to anyone who can help me out on this
J. Durgan
Re: HCX2001 on a Kaypro 4
You can change the emulator behavior with the hxc software. Which behavior / setting to do you want to use ?
