Roland MC-50 error
sweet-mountain-24
Roland MC-50 error
Post by sweet-mountain-24 »
I think I'm having trouble with the disk image for the Roland MC-50 sequencer.
Can anyone share a known-good HFE file?
Current state: Gotek is installed in the device. It says "hXc" on its LED segment display on startup. I name my disk images DSKA0001.HFE, DSKA0000.HFE, .... The Gotek file selector buttons work, so if I have DSKA0000 and -0001 on the USB drive the Gotek will allow me to select 000 or 001 but not 002. Still, any attempt to use the MC-50's disk Initialize function fails with the error Attn No Disk.
Things I've tried: mc50_shugart image from another thread, RolandMC-50_EmptyDisk.img from another thread, and one I created using the Linux mkdosfs command. For the *.img files, I use the HxC FloppyEmulator tool to create the *.hfe files. I've tried setting the System Family and Interface Mode on the Gotek...neither the "Generic Shugart DD" or the "S950 DD" settings found on https://hxc2001.com/docs/gotek-floppy-e ... tings.html make any difference. Tried two different brands of USB stick.
Any help GREATLY appreciated.
sweet-mountain-24
Re: Roland MC-50 error
Working now!!
I moved a jumper on to S0. Now, the green light on the Gotek is on. I think this should be added to a Troubleshooting page: if the green light isn't on, you probably have a jumper problem.
Settings: a jumper on S0, setting 0 - 19 (Roland), 1-08 (Generic Shugart), 4-02 (indexed mode)
I used the mc50_shugart file in another thread, opening it in HxC Floppy Emulator and saving the HFE file. I renamed it to DSKA0000.HFE and put it on the USB stick.
sweet-mountain-24
mc50_shugart.zip
working HFE file
(30.63 KiB) Downloaded 4786 times
The working HFE file for the Roland MC-50.
Vxster
Post by Vxster »
I know this is going to sound stupid but I've spent a long time searching around and I really can't find the answer.
I have a Roland MC50 with the 720k gotek installed. This was done by someone else...I bought it unknowing...I thought it still had a floppy drive in it.
Anyway, the gotek works...initialized a usb stick, saves, loads all just fine. The only thing is I am completely clueless as to how to see it on my windows 10 pc. I have the hxc software I have the blank image files...just no idea how to actually do it. Please could someone point me in the right direction.
I want to be able to move images around for backups etc. Sorry for my stupidity.
Vxster wrote: Thu Apr 10, 2025 12:59 am I know this is going to sound stupid but I've spent a long time searching around and I really can't find the answer.
Have you the hxc firmware installed on your gotek ?
If not, the starting point is : https://hxc2001.com/store/getlic.html
Vxster
Post by Vxster »
This is going to sound a bit stupid too....I haven't personally but as I bought the unit from someone who had installed it, I kind of guessed they had done it. Is there any way of checking or do I just go ahead and try it anyway?
Again...sorry for the stupid response!
Vxster wrote: Mon Apr 14, 2025 12:02 am This is going to sound a bit stupid too....I haven't personally but as I bought the unit from someone who had installed it, I kind of guessed they had done it. Is there any way of checking or do I just go ahead and try it anyway?
what is printed on the gotek screen ?
Vxster
Post by Vxster »
It has a two digit red LED display. It says '00' whatever I do with it. Saving, loading, whatever. Does that help at all?
Vxster wrote: Sun Apr 20, 2025 2:01 am It has a two digit red LED display. It says '00' whatever I do with it. Saving, loading, whatever. Does that help at all?
And what if you remove the usb stick ?
Vxster
Post by Vxster »
The display is still "00". The only thing I can see that changes is that the green light comes on when it is saving or loading a song.
Edit: Sorry...I misread your post. If I start with the USB in or out, put the USB in when it is on, or take it out, the display still says "00"!
Vxster wrote: Sun Apr 20, 2025 1:44 pm The display is still "00". The only thing I can see that changes is that the green light comes on when it is saving or loading a song.
Ok this means that you don't have any bootloader installed on this unit. You need to use an usb a usb a cable or serial ttl cable to install the firmware :
https://hxc2001.com/docs/gotek-floppy-e ... ial-method
https://hxc2001.com/docs/gotek-floppy-e ... usb-method
Vxster
Post by Vxster »
Thank you so much for your help. I'll try this with a USB type A to type A cable and see how it goes!
