USB_Floppu_Manager_v1.40i
Krular
Post by Krular »
When i format a USB stick using USB_Floppu_Manager_v1.40i. And create multiple floppy folders or say 10 floppy folders. How can i see them in Windows 10? When i plug the USB in all i see is FLPPY0 D: I click it to open the USB but it is blank with nothing there.
Jeff_HxC2001
Re: USB_Floppu_Manager_v1.40i
Post by Jeff_HxC2001 »
Krular wrote: Wed Aug 17, 2022 8:25 pm When i format a USB stick using USB_Floppu_Manager_v1.40i. And create multiple floppy folders or say 10 floppy folders. How can i see them in Windows 10? When i plug the USB in all i see is FLPPY0 D: I click it to open the USB but it is blank with nothing there.
Is the HxC firmware installed on your Gotek ?
jbarabas
Post by jbarabas »
This is an old thread but I have the same question/problem. After formatting my 2Gb USB stick with this progam, it shows up as a single floppy drive in Win11.
The content of the floppys are not visible from Win11. Is it supposed to be like that?
Cheers,
Janos
jbarabas wrote: Thu Apr 24, 2025 9:39 pm Hi,
Cheers,
Janos
Yes, i think so. USB_Floppu_Manager_v1.40i don't generate any partition table.
If you want to see multiples partitions :
emulation-from-partition.html
