OLED not working (sometimes) Newest Version
macsonny
Post by macsonny »
Hi All,
AFter 30 years being away I’m back into Atari ST’s having bought an Atari 1040 STFM recently. In the process of recapping and refurbish the machine and close to being finish. I’ve bought a new GoTek and spent a few days working out how to reflash as it’s a new model and has to be reflashed via the USB<->USB cable method. Anyway, now flashed to latest firmware.
I’ve installed a speaker in the GoTek and also the OLED screen. The issue is that the screen has really only worked a few times. I’ve been a bit lucky getting it going with a reset on the two pins on the GoTek and/or a long press on the front buttons on boot. However, I can’t get the screen to work consistently.
I’ve done some reading and it looks like it might be a timing issue and apparently I can fix with a firmware update. Issue is, I have the latest firmware installed. So I’m a bit stumped on what to do next?
Hope someone can help.
Sonny
Re: OLED not working (sometimes) Newest Version
What can you read on the Gotek screen without any usb stick connected ?
macsonny
Post by macsonny »
Nothing shows on the screen - it's just blank most of the time. When it does work - it works perfectly.
I managed to flash the 3.27 FlashFloppy firmware into the unit. I have the newer version with the Artery chipset so it was a little difficult to work out but finally got it flashed.
I have since purchased the firmware from www.hxc2001.com but there isn't a HEX file in the package that I can use to flash my device and I can't work out how to get the boot loader firmware flashed into the device as again - thee is not hex file to load the boot loader via the Artery flashing software.
I'm stuck and need help!
I have sent to you the hex and dfu files by email
Jeff wrote: Thu Jul 22, 2021 12:08 am I have sent to you the hex and dfu files by email
Forwarded 2 more times. Let me know if you have receive it.
macsonny
Post by macsonny »
Thank you!
macsonny
Post by macsonny »
Jeff wrote: Thu Jul 22, 2021 12:10 am
I have not received anything. Have you got my email from the purchase I made 12 hours ago?
macsonny wrote: Thu Jul 22, 2021 12:23 am
Yes.
Probably blocked for some reasons by your ISP. Please send me an email with another address.
macsonny
Post by macsonny »
macsonny wrote: Thu Jul 22, 2021 12:28 am Try macsonski@gmail.com
Done !
(EDIT : Time to sleep for me here... Availabe again in 8 hours... :) )
macsonny
Post by macsonny »
Still nothing? Is it caught up in your email queue?
macsonny wrote: Thu Jul 22, 2021 12:39 am Still nothing? Is it caught up in your email queue?
i don't know...
i have just retried without the attached files.
macsonny
Post by macsonny »
Ok. So just upgraded to the lastest have firmware. The machine boot done into the floppy selector software.
If I attached the 7 segment display it shows the correct information on the display.
As soon as I attach an OLED the display remains blank. I’ve tried two different OLDD displays with the same result. Also, my speaker used to work fine emulating sector reads but now I get nothing from the speaker either.
I’m really stuck. Ideas anyone?
Which power supply are you using ?
Please use the normal HxC firmware present in the firmware archive.
Please try this :
https://hxc2001.com/docs/gotek-floppy-e ... ork_strong
macsonny
Post by macsonny »
Thanks for your response. I'm using the power supply from the Atari ST floppy internal power.
With respect to "Normal HxC firmware - I have no idea which one is "normal" for my Atari ST with GoTek. Can you be so kind as to send me the specific link to the exact file I need?
I've also tried the reset a number of times with no luck.
Finally, I'll be honest in that there are multiple versions of AUTOBOOT.HFE and HXCSDF.CFG that just confuses me way too much. Which versions of those am I supposed to use for Atari ST?
Thanks again.
Sonny
