Reseting
MisteurJ
Reseting
Post by MisteurJ »
I'm trying to reset firmware settings on my Gotek, pushing the right button for 5 seconds, but no luck, doesn't seem to reset.
I managed to do it once, and now I can't, nothing happens...
What's wrong ?!
Thank you !! :)
Re: Reseting
What are you trying to reset exactly ?
MisteurJ
Re: Reseting
Post by MisteurJ »
Hello
I'm trying to reset the HxC firmware settings, as seen on this page :
https://hxc2001.com/docs/gotek-floppy-e ... tings.html
Re: Reseting
MisteurJ wrote: Wed May 05, 2021 3:36 pm Hello
I will reformulate : Why are you trying to reset the settings ? I am not sure to understand your issue.
Note : You can also use the reset eprom menu entry to do the same thing.
And btw what can you read on the gotek screen when no usb stick is present ?
MisteurJ
Re: Reseting
Post by MisteurJ »
Actually I made a few changes in the options, and it seems faster to reset all settings rather than modify settings one by one...
HxC is on the display when no stick inserted.
