Use IMG file directly
dpelan@woh.rr.com
Post by dpelan@woh.rr.com »
I'm running a Heathkit H-89 which supports multiple formats on the soft sector controller (40/80 track, 640k 800k, etc.). I currently convert my .IMG file which is a byte image of a disk to an .IMD file, then use HxC Floppy Emulator to convert to an .HFE file. Is there a way to use a .IMG file directly in the HxC flashed Gotek by supply some sort of configuration file?
Darrell
Re: Use IMG file directly
yes you can specify a custom img/raw file definition : https://hxc2001.com/custom_fw/
(see "User defined raw file image/disk format")
