Hi
I have a Gotek with the latest FW. It will Format the "Dynacord HD 1.6MB" image exported as *.hfe and the sampler verifies the image. This sampler is reported to read AKAI S900 disks which I cannot seem to read. Both HD and DD Akai s900 s950 images exported as "hfe" are reported as "unreadable" by the Dynacord ADS.
I have attempted to format both HD and DD Akai images, the HD "hfe" formatted and verified ok however the DD "hfe" reports directory errors directly after a format attempt?
attached are the format attempts, can anyone assist?
Dynacord ADS Sampler DD image incompatibility
- Dynacord ADS format attempts.zip
- (185.78 KiB) Downloaded 413 times
Re: Dynacord ADS Sampler DD image incompatibility
You probably need to force the interface mode to another mode. These images use the S950 DD / HD modes.
You can change this in the emulator's internal menu. Try the Shugart mode :
https://hxc2001.com/docs/gotek-floppy-e ... e_settings
