Emulate NEC FD1138D for embroidery machine
Hi, I'm new to the forum, this firmware can emulate an FD1138D for an embroidery machine that uses the ZSK or Tajima .dst format
Re: Emulate NEC FD1138D for embroidery machine
Hi,VortexH98 wrote: Wed Aug 26, 2020 5:38 am Hi, I'm new to the forum, this firmware can emulate an FD1138D for an embroidery machine that uses the ZSK or Tajima .dst format
Sure it can. It was already tested with the ZSK and Tajima machines.
Thank you very much for your answer Jeef.
Tomorrow I get the USB ttl, and I will also buy the firmware, but I have some doubts after having read the instructions.
I understood the first process First time bootloader Flashing / Programming process. after that I didn't really understand the firmware update process.
What Firmware should I use to emulate the FD1138D, and also if I only have to connect the USB with the file corresponding to the connected equipment.
- ACM330.jpeg (56.54 KiB) Viewed 5188 times
- FD1138D.jpeg (52.8 KiB) Viewed 5188 times
- 1.jpeg (54.05 KiB) Viewed 5188 times
Once you have flashed the bootloader, just install/update the normal firmware present into this archive :
Set the jumper to S0.
I already acquired everything I need, at the moment of flashing it gives me this error.
- puerto.png (10.54 KiB) Viewed 5170 times
I switched to windows 7 and it worked without any problem.
I already installed the firmware (* .upd). I will continue with the following steps.
I am using indexed mode.
I followed the steps in the foulder_mount folder, but in the emulator it displays the following Err message followed by a 000. And it does not transfer the design to the embroidery machine. Surely I am doing something wrong.
Have you some files images on the stick ?VortexH98 wrote: Sat Aug 29, 2020 12:10 am I am using indexed mode.
Is the machine supporting DOS/FAT file system ?
