Create boot disk for ASR-88 for a SFR1M44-U100K unit with USB Pendrive
ccubillos
Post by ccubillos »
Hi my friends,
I need your help, I'm just about to buy this device to emulate a severals floppy disks in my ASR-88:
https://es.aliexpress.com/item/32971657 ... 2e0e9OjHFS
Also donwloaded the imagen for ASR-10 OS which is: DSKA0005.HFE, and 2 program;
- HxCFloppyEmulator_Software
- Batch Manage Tool v1.40
Then I've formated with batch manager a 2 gigas USB Pendrive and got severals volumens of 1.44
Finally with HxCFloppyEmulator.exe I did loaded the DSKA0005.HFE file but cannot put it on the USB Drive due the image size is 3megas and the USB now has 1.44 mega size
So what are the step to put the OS in the pendrive and the boot from my keyboard (I've read lot's of post but still can't figure out which are the steps to do it)
Thanks you very much for your help!
Regards
Cristian
Re: Create boot disk for ASR-88 for a SFR1M44-U100K unit with USB Pendrive
You need to install the HxC firmware : https://hxc2001.com/store/index.html
