What means weto?
Coyote
What means weto?
Post by Coyote »
I would like to format a 720 KB img, then it appears the message WETO.
What means this message?
We need a empty 720KB image, because with the Emulator Sofware we can`t create it.
Thanks Coyote
shprivat
Re: What means weto?
Post by shprivat »
Coyote wrote:I would like format a 720 KB img, then it comes the message WETO.
What means dis message?
Thanks Coyote
Means "Write Error - Timeout". The SD card floppy emulator does not support the formatting, you have to create empty *.hfe files from within the Windows software (HxC Floppy Emulator Software).
Coyote wrote:I would like to format a 720 KB img, then it appears the message WETO.
Thanks Coyote
This means "Write Error - Time out".
With which computer are you using the emulator ?
Coyote
Answer
Post by Coyote »
I use a Pentium II with Win 98Se for testing. Late this drive should be works on a old CNC Lathe to replace the 720 kB Drive.
Can you say me why i can`t create a img with the Software? Also i can`t create FM track type. In config file it is the same. The emulater append the Message: BAD HXCSDFE.CFG.
Can anyone give me an empty 720kB img and a configfile with following options: Mode: IBM PC 720kB, Drive ID: DRVSA, Twisted cabel: none, Auto: none, Disable Drive: none
Or other assistance as I am currently in Indonesia with poor Internet availability.
Thanks to all who help me here
Coyote
Re: Answer
Coyote wrote:I use a Pentium II with Win 98Se for testing. Late this drive should be works on a old CNC Lathe to replace the 720 kB Drive.
Coyote
You can create an empty HFE file image !
To do this :
-> Click on the "Load Raw image" button
-> Set the floppy parameters of your target (number of track/sector/side...)
-> Click on the "Create Empty Floppy" button
-> Click on the "Export" button and save the Empty HFE file.
You can also create an MSdos floppy disk:
-> Click on the "Create FS Floppy" button.
-> Choose the floppy type (example : "720KB MS DOS FAT12").
-> Click on the "Inject directory" button.
-> Select a folder with somes that you want on the floppy.
-> Click on the "Export" button and save the HFE file.
For the HXCSDFE.CFG file :
-> Menu Drive -> SD HxC Floppy Emulator Settings
-> Click on the "Save" button and save this file to your Sdcard.
(Note: The SDCard must be formatted in FAT32).
Coyote
I will try it
Post by Coyote »
I will try it. Hope I can report me if something is working. Thanks for the quick help.
@Jeff an others: Gratualtion for this work, because on the PC it is running very well with a 1,44MB. If the whole is also working on the Lathe, it is even a little unbeatable work. Thx
Coyote
Bad HXCSDFE.CFG
Post by Coyote »
The problem with the image is resolved. But the configfile will not created. I don`t know what it is. It will only work with the configfile from your download on the PC.
thx
Coyote
Re: Bad HXCSDFE.CFG
Coyote wrote:...But the configfile will not created...
mhhh strange, are you sure ?
Coyote
Are your sure?
Post by Coyote »
Oh yes. I´m really sure!
Once I even create a configfile, says the emulator Bad configfile.
Oh i have to say that the config files are created on a WinXP and also on an Win7.
If you send your E-mail adress i will send you my Config File.
Thx Coyote
Re: Are your sure?
Coyote wrote:Oh yes. I´m really sure!
Thx Coyote
How did you create the file ?
Did you use the lastest software verion ? :
Coyote
Yes, of course
Post by Coyote »
I used the actually software.
And i create it with this. I saved the software directly on the SD Card. And every time the emulator said: bad configfile, whatever configs i have chosen.
Re: Yes, of course
Coyote wrote:I used the actually software.
What is your firmware version ?
Could you send me the config file present on the sdcard ?
Is your SDCARD formatted in FAT 32 ?
Coyote
Post by Coyote »
The firmware version is the actually V1.1.2.3 and yes my SDCARD is FAT 32 formated. I will send you a configfile urgently on your E-Mailadress.
Coyote
