I tried installing a Gotek HxC in a Yamaha VL1 today which didn't work out well
Can you confirm the Jumper Settings for the VL1? I think the hardest part when I did the VL7 and was building the 34 to 26 cable (thanks to Jeff's schematic) and I paid no attention to the Jumper Settings. If it had been something irregular I'm sure I would have made a note of it for future reference. (If I recall correctly the VL1m might have already had a 34 pin drive, at least I don't remember needing to make a cable
Perhaps the VL1 itself is faulty. I've tried 2 different Goteks and I also desoldered the 34 to 26 adapter from the original floppy drive to use with a Gotek in the case that my cable build was faulty.
