Gotek flash floppy akai s900
Thanosk
Post by Thanosk »
Hello I think I made a wrong purchase, is it possible to set up a gotek flash floppy on akai s900 without hxc?
This is what I bought
https://www.ebay.co.uk/itm/142722244180
Thanks for your time
Re: Gotek flash floppy akai s900
The hxc firmware can be installed on this with just an usb stick. Quite easy to do.
Thanosk
Post by Thanosk »
Jeff wrote: Mon Feb 17, 2020 9:38 pm The hxc firmware can be installed on this with just an usb stick. Quite easy to do.
Thanks for your reply, I read that you need to program the device and it's kind a complicated task,if it's that simple is there any guide to do it?
Thanosk wrote: Mon Feb 17, 2020 10:17 pm
No with the usb stick method this is quite simple : copy some files to the stick to update the drive.
Thanosk
Post by Thanosk »
Jeff wrote: Mon Feb 17, 2020 10:28 pm
Thanks, also hxc is free or I have to purchase it?
You can get it there :
https://hxc2001.com/store/
Thanosk
Post by Thanosk »
Jeff wrote: Mon Feb 17, 2020 11:17 pm You can get it there :
Thanosk
Post by Thanosk »
Because I am confused I am gonna ask again, I have to install the firmware and after the software, or I don't need the firmware and I can install only the software
Thanosk wrote: Tue Feb 18, 2020 2:03 am
You have to install the hxc bootloader and then hxc firmware. All of this can be done with an USB stick.
