OSD feature : Separate VSYNC.
tzok
Post by tzok »
Will the OSD work with Composite Video instead of Composite Sync? There is no Composite Sync readily available in the STFM nor in STE (except the French STE version, which had no TV modulator).
Re: HxC firmware for Gotek drive instructions
tzok wrote: Thu Aug 01, 2019 4:56 pm Will the OSD work with Composite Video instead of Composite Sync? There is no Composite Sync readily available in the STFM nor in STE (except the French STE version, which had no TV modulator).
The last firmwares support the separate HSYNC/VSYNC synchronisation. You need 3 wires instead of 2 in these cases. Tested on STFM.
See the custom firmware request page to have the VSYNC input : https://hxc2001.com/custom_fw/
