Casio FZ 10m problems with Gotek
ghostinthemachine
Post by ghostinthemachine »
i have installed an Gotek Emulator with the HXC Firmware and Oled Screen. After installing the Gotek in the Casio FZ10m. It only starts when a USB Stick with and HFE File is inserted, if i take out the Stick it hangs and does not boot at all. Any Ideas why this is happening? Anyone who got this working on an FZ10m?
Jeff_HxC2001
Re: Casio FZ 10m problems with Gotek
Post by Jeff_HxC2001 »
ghostinthemachine wrote: Thu Aug 08, 2019 1:22 pm Hi,
Which firmare version have you ?
What is displayed on the gotek screen without stick inserted ?
ghostinthemachine
No USB Stick found
push up down for menu
when i enter the menu and check for the software version: 3.1.23.1aL
ghostinthemachine wrote: Thu Aug 08, 2019 2:34 pm No USB Stick found
Try to update to the latest firmware :
ghostinthemachine
Jeff i updated to the latest Firmware but still the same. With USB Stick and HFE File it boots without it hangs on the FZ-10m Boot Screen.
ghostinthemachine wrote: Thu Aug 08, 2019 2:55 pm Jeff i updated to the latest Firmware but still the same. With USB Stick and HFE File it boots without it hangs on the FZ-10m Boot Screen.
Try to force the interface mode : Press both buttons to enter the menu, choose "Interface cfg" then "shugart" and "exit".
ghostinthemachine
I tried that with the shugart mode. but still the same problem.
is there an image out there with the optional software for ram testing the FZ Sampler?
ghostinthemachine
what is the jumper setting for the Casio FZ?
ghostinthemachine wrote: Thu Aug 08, 2019 5:22 pm what is the jumper setting for the Casio FZ?
S0 i suppose, but let's check the setting : What was the old drive brand and model and what is its jumper setting ?
ghostinthemachine
I tried S0, Mo, S0+Mo no luck.
It hangs till i put a usb into the emulator.
ghostinthemachine wrote: Wed Aug 14, 2019 1:40 pm I tried S0, Mo, S0+Mo no luck.
No idea about the floppy disk drive brand & model ?
ghostinthemachine
Matsushita FMD02290B4
ghostinthemachine wrote: Wed Aug 14, 2019 11:33 pm Matsushita FMD02290B4
FMD02290B4 is not the product model.
ghostinthemachine
It is JU-255
Can you share the images you are using ?
