Gotek 7-Seg change letters hxc
Hi Jerry
There is a way to change the letters hxC in 7 segments display while there is no pen drive inserted?
Nelson
Nelson
Re: Gotek 7-Seg change letters hxc
Not yet, but i will add this option quite soon on the custom firmware page :NelsonZ wrote: Fri Jun 28, 2019 2:04 am Hi Jerry
Nelson
Thank you. An other function I missing is the auto fast increment the diskete number if I press the button for more than 2 seconds. It is possible to implement?
Already implemented, but you may need to press the button more than 2 seconds. Will add these parameters in the custom firmware page too.NelsonZ wrote: Fri Jun 28, 2019 2:00 pm Thank you. An other function I missing is the auto fast increment the diskete number if I press the button for more than 2 seconds. It is possible to implement?
I download new firmware. Works perfect. Thank you.
You can now change the 7 segments letters : https://hxc2001.com/custom_fw/
Hi Jean
The firmware file are coming empty.
Nelson
Nelson
Hi Jeff
In older firmware versions if I hide the cfg file it recognized it. In new version it only recognze cfg file if it is not hidden. I use a cfg file with a name as abcdef.ghi and diskete files as ABCD0000.EFG, I don't know if this make any difference.
Yes you are right. I will publish a new version in ~10 hours supporting hidden files for cfg file (and others fixed file name/paths).NelsonZ wrote: Thu Jul 11, 2019 12:54 am Hi Jeff
Hi Jeff
Is not working yet. Just recognize cgf if is not hidden.
Should be fine now : https://hxc2001.com/custom_fw/NelsonZ wrote: Fri Jul 12, 2019 2:22 am Hi Jeff
Hi Jeff
Is still not working.
