Akai S Series cross compatibility
j1mpst3r
Post by j1mpst3r »
Considering the models of Akai S series Samplers can read floppy disks from other models without issue. Am I correct to assume this is not possible with HFE files. The reason I ask is because I'm having no luck with an S3000XL reading HFE files created on an S1000. It just says "no disk"
J
Re: Akai S Series cross compatibility
j1mpst3r wrote: Fri May 24, 2019 4:41 pm Hi Jeff,
J
Sure it is possible. You must set/force the floppy interface mode matching with the S3000XL into the embedded menu or in the config file.
j1mpst3r
Post by j1mpst3r »
Thanks for the prompt reply as always Jeff.
I would be grateful if you could explain how I would do that.
J
j1mpst3r wrote: Fri May 24, 2019 6:05 pm Thanks for the prompt reply as always Jeff.
J
With oled/lcd screens : Remove the stick, press both buttons, select interface cfg , ibm pc hd, exit.
With digits screen : Remove the stick, press both buttons, select '1', then '02'.
menu meaning there :
https://hxc2001.com/docs/gotek-floppy-e ... gotek_menu
j1mpst3r
Post by j1mpst3r »
Thanks Jeff, I got lost and ended up on the custom firmware editor :oops: I'll do what you said and check the link.
