Kurzweil K2000 formatting disk verified failed [error]
teevee
Post by teevee »
Hi HxC Folks,
I wanted to make a blank disk for my Kurzweil K2000RS, which can be used to save my work on, so I have insert a random downloaded .KRZ disk [K2000 raw format], which has been converted with the HxC Floppy Emulator to .HFE.
My Floppy Emulator is running firmware version 3.1.46.1A
I have attached two examples [Pictures], one where I let the K2000 format it as 720k and one as 1.4 MB.
Both were not able to be converted.
Please see result of formating here:
https://www.dropbox.com/s/491fod41xxem1 ... g.zip?dl=0
Re: Kurzweil K2000 formatting disk verified failed [error]
You can't format a HD HFE as a DD image.
Anyway just use an 1.44MB DOS IMG file (attached).
Disk_Image.img.zip
(2.41 KiB) Downloaded 2540 times
EDIT : Btw which usb stick are you using ? (brand & model?)
teevee
Post by teevee »
Hi Jean,
The usb stick is no-branded and the cheapest possible found on eBay, but they have worked fine so far for loading and saving.
When I convert your provided disk image to .HFE and try to format it, then I get “Verify failed!, Track: 0”.
I came to a work-around as deleting the .KRZ files manually instead of formatting.
teevee wrote: Fri Apr 26, 2019 10:35 am Hi Jean,
you don't need to convert it : the firmware directly support img files !
I think that your usb stick is just too slow for the hfe format process.
this should work better with img files in your case.
Naut.Sirius
Post by Naut.Sirius »
Jeff wrote: Fri Apr 26, 2019 9:59 am You can't format a HD HFE as a DD image.
Disk_Image.img.zip
So if I'm reading this right, if I only wish to create blank floppy images for my K-2000 to use (I.E. I don't have any interest in downloading and transferring sounds off of the internet) then all I have to do is copy over that 1.44MB DOS IMG file and create duplicates with name variations and the kurzweil will just save to those images?
