Help with embroidery machine
eduardo
Post by eduardo »
This is my first post so hi everybody, I need help with my BAS 416 embroidery machine, I succesfully flashed the HXC firmware to a GOTEK usb emulator with 2 digit 7 segment screen to replace the original FDD Teac FD-235HF-7579, but I haven't been avil to make it work with my embroidery machine, I try JEFF instrution in other tread about the same machine creating the HFE file but the machine only shows READYING on the LCD screen, I'm attaching the recomendation below and the HFE file I'm made following the instruction below,
Re: replacement for FDD Teac FD-235HF-7579
Post by Jeff » Thu Feb 02, 2012 8:18 am
dron wrote:
Hey, You made it!!!
Image from todays morning FDD2_DD_HD.hfe is working!!!!
I have conected emulator to PC, inserted few more embroideries to image for control and this modified images is working (include new inserted files) !
Thank You so much :o) With what setting did You force it work? :o)
Could I have one last question? How I could re-edit images without present emulator in PC? (for example - if I want to ad one file to "old" image).
Thank You - for some time I do not belived that it will be OK...
:o)
dron
So the HD state line is inverted on this machine...
To change the line state :
-> Start the HxC Floppy Emulator software.
-> Settings -> "HFE file interface mode" -> uncheck auto -> set "IBM PC 720kB"
-> After use the "Create FS Floppy" with the "3"5 1.44MB DSHD FAT12" format.
-> Export the HFE file.
I try all config normal, indexed, autoboot making no diference, the internal parameters are set to default
The firmware I use is latest HXCFEUSB_V3_1_23_1a
Any help will be apreciated
Thank you
DSKA0000.zip
HFE file
(66.27 KiB) Downloaded 699 times
Re: Help with embroidery machine
You must use the indexed config file.
what is displayed on the gotek screen and how is the gotek led ? is it lit all the the time ?
eduardo
Post by eduardo »
Thank you Jeff
When the machine is turned on the GOTEK shows Hc on the screen no USB inserted the led is off, after inserting the USB with the index configuration and the HFE file the screen on the GOTEK change to 00 the led is off, after pressing the read botton in the embroidery machine the led lit for one or two seconds and then off the screen on GOTEK still 00 no error signal on the machine or the machine LCD screen, after 2 or 3 min the machine LCD shoes error signal.
What is your machine model ?
eduardo
Post by eduardo »
Brother BAS-416A
eduardo wrote: Sun Sep 23, 2018 7:41 pm Brother BAS-416A
Try the "Not_Gated_Firmware" firmware :
eduardo
Post by eduardo »
I flash the GOTEK with the no gated firmware HXCFEUSB_V3_1_30_2a_NG.UPD, but now the machine LCD screen shows error as soon as I hit the read botton on the panel control, I try no the junper, jumper on S0 and jumper on s1 same result error and error sound on the machine.
eduardo wrote: Sun Sep 23, 2018 11:19 pm I flash the GOTEK with the no gated firmware HXCFEUSB_V3_1_30_2a_NG.UPD, but now the machine LCD screen shows error as soon as I hit the read botton on the panel control, I try no the junper, jumper on S0 and jumper on s1 same result error and error sound on the machine.
Ok then use the normal firmware, set the S1 jumper. Enter the internal menu ( see https://hxc2001.com/docs/gotek-floppy-e ... gotek_menu - Original 7 Segments Gotek Menu) and try the interface mode IBM PC DD, IBM PC HD, GENERIC SHUGART DD, S950 DD and S950 HD.
eduardo
Post by eduardo »
Jeff, I try the normal firmaware, jumper to s1 and all the interface mode IBM PC DD, IBM PC HD, GENERIC SHUGART DD, S950 DD and S950 HD bun non of them make any difference, I can see the led lit for one second then off and the machine panel control shows READYING only, but I can´t see the DST files to save into the machine memory to do the embroidery.
Any other ideas,
Maybe the HFE file I´m creating is not correct
This below is what you post to someone else for this especific machine,
Thank you
Press the gotek right button at power up clear/reset all settings to the default values, and try these images :
https://hxc2001.com/download/bas_test.zip
aminesay
Post by aminesay »
I have a similar machine which reads and writes to the hfe files contained in the attachment, but once written a program can't be modified on the machine and writing is limited to only one pattern per hfe file which is very inconvenient.
hfe bas.zip
(176.14 KiB) Downloaded 751 times
aminesay wrote: Fri Oct 05, 2018 9:13 pm I have a similar machine which reads and writes to the hfe files contained in the attachment, but once written a program can't be modified on the machine and writing is limited to only one pattern per hfe file which is very inconvenient.
Is this limitation "normal" or it is an issue with the floppy emulation ?
aminesay
Post by aminesay »
Actually by similar machine I meant a bas 403.
This limitation is of course "abnormal". But that's the best i could get, by using the profile AKAI950.
I have sent you the disk dump by email.
aminesay wrote: Mon Oct 15, 2018 8:28 pm Actually by similar machine I meant a bas 403.
your image is not good.
New image to test sent !
