Akai S900 OS4 onto usb stick
Kna
Post by Kna »
Hi everyone,
I have just installed a Hxc-flashed Gotek USB-drive in my S900, and it works like a charm.
Im using a 8GB USB-stick with 1000 empty disk images on it (found on net).
Only step left now is to upgrade to OS4 to get that filter envelope.
My question is, how do I get OS4 onto these disk-images? I assume I have to put them onto every disk so the OS can load with every disk?
Or is it sufficient to put OS4 on disk image 000 of the Gotek, and load this first every time I start up (sounds cumbersome)?
In any case, I need to put OS4 on a/many USB - disk images. Anyone know how to do this?
Oh, Im running OS 1.2.
Re: Akai S900 OS4 onto usb stick
Kna wrote: Sat Sep 23, 2017 1:05 am Hi everyone,
I am not an expert on this machine, but it maybe need some EPROM reprogramming ?
Someone else know ?
Kna
Post by Kna »
Its supposed to work with just loading OS4 from disk if you're already running OS 1.2
What I dont understand is how I put the OS on the disk images?
Kna wrote: Sat Sep 23, 2017 8:12 pm Its supposed to work with just loading OS4 from disk if you're already running OS 1.2
Ok got it : need to convert the raw image file to hfe : use the load raw file button in the hxc software and use the S900 predefined format, then load and then you can export the hfe file.
Kna
Post by Kna »
Thanx, reply much appreciated. Actually, I dont understand the HxC software at the moment. I´ll look into it and see if it makes sense eventually...
Kna wrote: Sun Sep 24, 2017 8:49 pm Thanx, reply much appreciated. Actually, I dont understand the HxC software at the moment. I´ll look into it and see if it makes sense eventually...
Page 8 :
Kna
Post by Kna »
Ok, thanks. :)
