Skip SD card detection possible ?
freshworks
Post by freshworks »
Is there any possibility to skip te SD card detection, so i mean when i put the SD card in a floppydisc cable, i don't have the presence and protection switch ?
How can i simulate these or make a simple workaround ?
Thanks and greetz,
Jasper
Re: Skip SD card detection possible ?
freshworks wrote:Hi,
Thanks and greetz,
Jasper
i don't understand. what do you mean by "when i put the SD card in a floppydisc cable" ?
freshworks
i mean i don't have a SD card socket at the moment and used this sollution:
So now i don't have the:
SD_WR_PROTECT and SD_PRESENT connections and the standalone always says no card detected.
Cheers,
Jasper
freshworks wrote:Hi Jeff,
Cheers,
Jasper
SD_WR_PROTECT and SD_PRESENT are not used by the firmware. the firmware try to initialize the sdcard to check its presence.
freshworks
i've killed an SD cardreader and used the SD slot, now it's working OK.
Jasper
neverdaie
Post by neverdaie »
excuse me, i have the same problem: " No sd card found_" qu' it was the solution of freshworks?
