Sequential Circuits Prophet 3000
sbmayer99
Post by sbmayer99 »
Hi Jeff.
I've got two Sequential Circuits Prophet 3000 samplers that I would like to set up with HxC drives. I already own several HxC drives for other samplers I have, but this is the first one that is unsupported. Is it possible for you to add support for the Prophet 3000? If so, I assume I need to send you some boot disks and formatted disks, but I don't know the exact procedure. Please let me know required steps and I'll be happy to provide what's needed.
Thanks in advance.
Steve
Re: Sequential Circuits Prophet 3000
sbmayer99 wrote:Hi Jeff.
Thanks in advance.
Steve
You need to make some dumps of your disks :
Page 14 : "How to make a disk image from a floppy disk ?"
Once done please share them, i will check.
Then you need to set the right interface mode (probably shugart or PC...) and the right switch setting.
For this i need know the floppy drive brand & model + a picture of its jumper block.
sbmayer99
Post by sbmayer99 »
OK, great, I will follow your instructions and reply asap!
Thanks.
sbmayer99
Post by sbmayer99 »
Hi Jeff.
I'm not sure I'm doing this right, but I made two versions of a dump I made from a Prophet 3000 OS disk. I've attached an .img to this post.
P3000_OS204a.img.zip
(122.88 KiB) Downloaded 1151 times
sbmayer99
Post by sbmayer99 »
Here's an .hfe version
P3000_OS204a.hfe.zip
(194.71 KiB) Downloaded 1167 times
sbmayer99
Post by sbmayer99 »
I'll follow up with the floppy drive info asap.
sbmayer99 wrote:Here's an .hfe version
Perfect. You have now to copy this HFE to the sd, and plug the HxC to the Sequential Circuits Prophet 3000.
sbmayer99
Post by sbmayer99 »
Hi Jeff.
I pulled out the floppy drive to check the model and get a picture of the pin block.
Model #
ye-data 701 6031
Here is a link to a web picture and a bit of info:
http://www.recycledgoods.com/media/cata ... e-2.20.jpg
Here's a link to pictures I took of the drive AND the pinblock:
https://drive.google.com/folderview?id= ... sp=sharing
I hope you can figure out the right interface mode and switch setting from this info.
Steve
sbmayer99
Post by sbmayer99 »
Hi Jeff-
Just a quick bump to remind you that I need instructions for setting the interface mode and switch settings to move forward on this. Please correct me if I'm wrong.
Steve
Switch setting : ID0-A.
Interface config : Try IBM PC 1440, shugart or IBM PC 720.
(for this remove the sd, press select -> choose interface cfg)
