Korg Trinity + Gotek with HxC problem
Re: Korg Trinity + Gotek with HxC problem
alchemist wrote: Sat Dec 02, 2017 10:35 pm Hi Jeff,
I have the same results with the MO jumper set.
Are you waiting some seconds after the image selection ?
Try this : Make a contact between the S1 jumper and the ground. This will permanently select the gotek (led green always lit) but this have solved this issue with the previous user.
alchemist
Post by alchemist »
Jeff wrote: Sun Dec 03, 2017 11:07 am
Yes. No action cannot be done (click on file or open the menu), the system says always "medium changed".
Jeff wrote: Sun Dec 03, 2017 11:45 am Try this : Make a contact between the S1 jumper and the ground. This will permanently select the gotek (led green always lit) but this have solved this issue with the previous user.
I will try it, but this is not a solution for me. Can't it be done through a software feature?
Could the official HxC drive work? In that case, I will sell my gotek and buy a HxC.
Kind Regards,
Xavier Miller
Why this is not a solution ?
I can do this in software, but a small wire is an immediate solution ;)
Try this firmware :
https://hxc2001.com/vrac/HxCUSBFEUNGATED.UPD
No jumper needed with this one.
EDIT : This file can now be generated from the custom firmware page :
Set "Non gated mode" and request the firmware (see the last "Build order" section).
alchemist
Post by alchemist »
Thank you Jeff, I will try it this evening :)
Kind Regards,
Xavier Miller
alchemist
Post by alchemist »
Jeff,
IT'S WORKING !!!!
8) 8) 8)
Thank you very much !
Is there a "beer" button, you owe a full pack of it ! :wink:
Kind Regards,
Xavier Miller
