Re: Firmware updates for the STM32/Gotek HxC floppy emulators !
18 April 2022 : Firmware STM32/AT32 USB HxCFloppyEmulator v4.2.X.Xa - Pre Release
(Cumulative release notes - Work In Progress ! Latest version : v4.2.10.10a)
(>>> Please find these WIP firmwares in the "WIP_Firmware" folder ! <<<)
- (18 April) : QFN32/SFRKC30.AT2 Gotek :
Fix possible 7 segments screen issues.
Fix possible bus gating issues.
HXCFEUSB_Gotek_HxC_firmware.zip
Custom HxC firmware
8 August 2022 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.0.0.4a - Pre Release
- A new series of Goteks based on the new AT32F435 is now available (PCB "SFRKC30.AT4.35").
This MCU is more powerful than the previous AT32F415 MCU.
- The AT32F435 has 384KB of RAM ! (This was 32KB for the AT32F415 and 64KB for the STM32F105)
- The AT32F435 can run at 288MHz ! (This was 150MHz for the AT32F415 and 72MHz for the STM32F105)
This hardware revision removes the 32KB memory size challenge introduced by the "SARS-CoV-2" Goteks (based on the AT32F415).
This is definitively more reliable because file system cache can be properly implemented to deal with the USB stick latency.
I strongly recommend this new AT32F435 Goteks hardware revision.
Regarding the HxC firmware the new v5 version is now compatible with this new core.
It still compatible with the STM32 and AT32F415 Goteks.
- Others changes:
- Artery AT32F415 Gotek now runs at 144MHz ! (the v3 & v4 run this core at 72MHz)
- Many changes and some fixes in the low level layers.
- The bootloader was updated too and finally gain the OLED screen support.
- The offline firmware installation (activation at hxc2001.com) now supports this new core.
- The online serial installation doesn't support yet this core. But this will be done next week.
Custom HxC firmware
17 August 2022 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.0.0.5a - Pre Release
- Fix internal interrupts priorities.
- Some optimizations. (OLED I2C Layer, head step irq).
Update recommended.
Custom HxC firmware
13 September 2022 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.0.0.7a - Pre Release
- Another internal interrupts priorities fix : Fix possible read issues
with some usb sticks brand/models with HD disk images.
(v5.x.x.x regression fix)
Update recommended.
Custom HxC firmware
15 September 2022 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.0.1.1a - Pre Release
- New custom firmware page and build options :
- CONFIG_OLED_TURN_OFF_STANDBY : Turn off OLED screen when entering standby instead of dimming it.
- CONFIG_OLED_PAGE_OFFSET : Allow to add a top margin on the screen.
- CONFIG_OLED_MAX_TXT_LINE : Allow to force / define the allowed maximum text lines.
Online build page : https://hxc2001.com/custom_fw/
11 December 2022 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.0.2.11a - Pre Release
- Quickdisk emulation with AT32F435 Goteks : the whole image is now fully prefetched/loaded in RAM (better reliability)
- Properly detect SFRKC30.AT4.35 boards vs "standard" board with F435 MCU.
- New custom firmware page and build option :
- CONFIG_OLED_CHAR_X_OFFSET : OLED screen left margin.
Custom HxC firmware
3 January 2023 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.0.3.4a - Pre Release
- On screen display / OSD : AT32F435 / SFRKC30.AT4.35 Goteks compatibility added.
Custom HxC firmware
8 January 2023 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.1.1.1a - Pre Release
- Apple II Support added :
Floppy interface mapping :
               Apple II floppy interface  <------------------> Gotek floppy interface
               (Int 20pins / Ext DB-19)
        PH0    (Int pin  2 / DB19 pin 11) <------------------> UART RX Pin (J4)
        PH1    (Int pin  4 / DB19 pin 12) <------------------> UART TX Pin
        PH2    (Int pin  6 / DB19 pin 13) <------------------> /DIR   (18)
        PH3    (Int pin  8 / DB19 pin 14) <------------------> /STEP  (20)
        /WREQ  (Int pin 10 / DB19 pin 15) <------------------> /WGATE (24)
        SEL    (Int pin 12 / DB19 pin 16) <------------------> /SIDE1 (32)
        /DRVEN (Int pin 14 / DB19 pin 17 or pin 9 *) <-------> /DS0   (10)
        RD     (Int pin 16 / DB19 pin 18) <------------------> /RDATA (30)
        WR     (Int pin 18 / DB19 pin 19) <------------------> /WDATA (22)
        WRPROT (Int pin 20 / DB19 pin 10) <------------------> /WPT   (28)
(*) pin 17 for the drive 1 - pin 9 for the drive 2.
- Currently supported file format : Standard HFE.
You can convert DO/PO/DSK/NIB files to HFE with the HxC Software.
- Write support not tested yet.
Demo : https://www.youtube.com/watch?v=B-pzItOAO1g
Screenshot at 2023-01-08 23-49-14.jpg (123.52 KiB) Viewed 716898 times
Custom HxC firmware
13 January 2023 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.1.2.1a - Pre Release
- Normal/direct selection mode : File sorting fixed for AT32F435 Goteks.
- System tick timer : Fixed for AT32F435 Goteks.
- Fix the hidden ".." entry issue (macOs create folders with the ".." entry hidden flag set...)
Custom HxC firmware
Note : Je déplace les posts dans un nouveau thread : viewtopic.php?f=33&t=4361
22 March 2023 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.1.3.1a
- AT32F435 Gotek : Fix RAM / Flash size option byte configuration if needed.
Some AT32F435 can have a different default memory configuration.
This fix the black screen/non working firmware update behavior on some units.
- Fix the build when the AT32F435 support is disabled. (custom firmware page)
- On screen display / OSD : PA10 (UART RX) video output option.
(CONFIG_VIDEO_OSD_OUT_PA10)
- Fix 2x16 LCD support.
22 May 2023 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.2.1.2a
- Apple II Support : Write support enabled.
- Internal optimizations.
Custom HxC firmware
20 March 2024 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.2.1.6a
- Apple II Support : Drives conflict issues on machines with more than a drive fixed.
30 May 2024 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.2.2.1a
- Apple II Support : Direct .dsk, .do, .po files images support.
4 June 2024 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.2.2.2a
- Apple II Support : Select button disabled on 32 pins AT32 Goteks.
(Fix hardware conflict with one of the Apple II floppy signal)
Custom HxC firmware
6 June 2024 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.2.3.1a
- Apple II Support : Direct .dsk, .do, .po files images support : Write support enabled !
Custom HxC firmware
13 May 2026 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.2.3.6a
- QFN32/SFRKC30.AT2 Gotek : Fix/implement Reset DC signal support.
- QuickDisk : Fix non-HxC QD images support.
- QuickDisk : Roland mode crash issue fixed.
Custom HxC firmware
3 August 2026 : Firmware STM32/AT32 USB HxCFloppyEmulator v5.3.1.1a
- NEC / Anex86 *.FDI file format direct support added :
Read and write operations supported.
All header sizes are supported.
- Amstrad CPC / ZX Spectrum EDSK & DSK : Image load time reduced.
- RAW files (*.IMG,*.DSK...) : Memory cache strategy improvement.
Custom HxC firmware
