Serial Bridge does not detect gotek
Secret_Oreo
Re: Serial Bridge does not detect gotek
Post by Secret_Oreo »
I will get back to you regarding presets as I haven't checked that side out yet. I'll get some modulation going in chords and see how she is with that ☺.
So far so good mate. Going into disk menu was quick also fyi. πŸ˜€
Secret_Oreo
Jeff wrote: Tue Nov 19, 2019 4:54 pm Ok then lets restart from the beginning.
Remove all files from your stick.
Unpack the files from the attached zip file.
- format each images ! (none are formatted).
- Post back them here !
- Try to save multi disk sample.
Note : wait 4 seconds before accessing the disk after changing the disk number, the auto select delay may be the issue.
e6400_test3.zip
Regarding the read speed this is probably a gap3 parameter setting issue. i will check this and come back to you with something to try.
Update:
Only just had time to load a few samples and make big patches using chords. Saving both short and long samples gave reasonable preset save/load times to previous times recorded. Some longer than others but obviously due to length of sample and amount of modulation.
So I would say all is well! πŸ‘πŸΎ
Do you have a tutorial for changing existing floppies to DSK.... images please? (IPF Converter?) πŸ€”
Just want to say thank you for your time and effort for all of this Jean!! 🍻
Secret_Oreo wrote: Sun Dec 01, 2019 4:27 pm Do you have a tutorial for changing existing floppies to DSK.... images please? (IPF Converter?) πŸ€”
Which computer able to read a floppy disk have you ?
Secret_Oreo wrote: Sun Dec 01, 2019 4:27 pm Just want to say thank you for your time and effort for all of this Jean!! 🍻
Thanks ! :D
lyche
Post by lyche »
I have a e6400 as well and trying to update the EOS version from 4.02 to 4.62 via HxC flashed gotek - the one without encoder. 7 Part Screen, two buttons and green led only.
One issue that is this thing is slowwww.
The second issue is that i can't be sure of the jumper setting on the gotek. Mine is currently set on s1 because that's the only setting in which i have witnessed that the led tuns on when there's a usb attached.
I am not sure if i am successfully formatting hfe images for the gotek. I have the EOS update images - in img format. downloaded from the bottom of this page http://zine.r-massive.com/e-mu-eiv-seri ... y-library/.
But i have not managed to boot from them. Probably didn't manage to properly convert them. Has anybody succeeded in this?
I've also tried the test images that you have attached. Could not read or format them
lyche
Post by lyche »
could anyone offer any help?
Jeff_HxC2001
Post by Jeff_HxC2001 »
lyche wrote: Fri Oct 03, 2025 12:58 am I have a e6400 as well and trying to update the EOS version from 4.02 to 4.62 via HxC flashed gotek - the one without encoder. 7 Part Screen, two buttons and green led only.
Please follow the instructions and files from this post :
viewtopic.php?p=21734#p21734
lyche wrote: Fri Oct 03, 2025 12:58 am I've also tried the test images that you have attached. Could not read or format them
use the attached files :
"e6400_test3.zip"
you must use the img files ! not hfe !
and :
Set the E-mu ESI/EOS mode in the menu 0 - Selection 1B :
See :
https://hxc2001.com/docs/gotek-floppy-e ... ction_span
