Akai S1100 Loading Issues
Jeff_HxC2001
Re: Akai S1100 Loading Issues
Post by Jeff_HxC2001 »
Please try this :
Jeff wrote: Mon Nov 30, 2020 11:35 pm One additional thing to try :
Request a custom firmware with the "Non gated mode" option set :
Jeff_HxC2001 wrote: Sat Mar 04, 2023 10:44 pm Please try this :
To be more specific :
- Go to this page : https://hxc2001.com/custom_fw/
- Set the "Non gated mode" option.
- fill your email address and send the request.
- you will receive an new UPD file by email - Update the firmware with this new firmware.
Please note that there is no need to reflash the whole bootloader and firmware ! This is is just an update ! So just follow this procedure :
einfall_industrie
Post by einfall_industrie »
tried the QuickInstall images for S900950 as well with no luck. It only reads the first image. For the others I get a NO DISK message. For the first as well I get Bad floppy disk error.
EDIT: just read the two last messages. Will do that asap.
einfall_industrie
Have taken this step you suggested and it definitely helps. However I remain with a few problems and have noticed that my sampler has an old OS v1.36 (newest is v4.3) so I will have to check that. Does anyone have the OS file on hand? I can only find programmed EPROMs and I only need the OS file. Hardware tests all run OK, 5MWords fitted.
It also hangs up on loading S900 S950 samples in the unscrambling step.
I get a lot of non-deterministic behavior when loading and it never gets to the end of loading an entire volume and ends with Bad floppy disk error.
einfall_industrie wrote: Sun Mar 05, 2023 7:56 pm It also hangs up on loading S900 S950 samples in the unscrambling step.
Which images are you trying ?
