Unable to boot or access floppy images
xohs
Re: Unable to boot or access floppy images
Post by xohs »
It's not an exe, it should be a zip. Here's the direct download link I just used, try this -
https://filebin.net/archive/9uucbyozyay ... t=3o2yh7h9
That resulted in a zip file, and upon uncompressing was the original zip en_msdos622.zip. If you are getting an .exe of any kind that's not correct.
Here's another link to the same file, I uploaded to a different place:
https://gofile.io/d/bjY8Jg
This seems to be an exe :
Screenshot at 2020-07-12 17-21-59.png (50.47 KiB) Viewed 3656 times
xohs
Post by xohs »
Ah yes inside the zip is a self-extracting exe as distributed from Microsoft. I extracted to a dir on my side and re-uploaded just the images.
Try this one. You should get 12UPG1.IMG, 144UPG1.IMG and so forth. I was testing with the 144UPG*.IMG files.
https://filebin.net/or8bdz6dilai5k6d
xohs wrote: Sun Jul 12, 2020 11:37 pm Ah yes inside the zip is a self-extracting exe as distributed from Microsoft. I extracted to a dir on my side and re-uploaded just the images.
ok
So these images are missing one track and theirs file size are not standard that's why the HxC tool doen't like them.
You can anyway load/convert them by using the "Load raw image" button and by choosing " Standard 3"5 DOS HD Floppy Disk".
