Weird problems with Gotek and Amiga 500
CrazyNob
Re: Weird problems with Gotek and Amiga 500
Post by CrazyNob »
Its a Floppy Ribbon from a PC but it doesn't have a twist. I also tried to connect the Gotek with the original Amiga Floppy Ribbon with the same result.
CrazyNob wrote:Its a Floppy Ribbon from a PC but it doesn't have a twist. I also tried to connect the Gotek with the original Amiga Floppy Ribbon with the same result.
Is the jumper set to S0 ?
Try to reseat the Paula chip into the Amiga.
CrazyNob
Post by CrazyNob »
Yes the Jumper is set to S0.
I have reaseated the Paula Chip but still the same.
The normal Floppy is working perfectly with this ribbon.
I have made some pictures of the Gotek MC.
The one working with the Cortex Firmware.
And the one working with the display and your firmware
Is this of any interest for you, maybe it is a problem with the Gotek Hardware.
Try to update the gotek with the cortex upd ( HM_CXFE_1_5.UPD ) and copy startup.adf to the usb stick
CrazyNob
Post by CrazyNob »
I have updated the Gotek with Cortex Firmware and copied the selector.adf to the Stick.
Its the same behvior. It loads until the Amiga dos message appears, it can be solved by using the "Ja" Button. Can i pay via Paypal to get the bootloader for the other Gotek?
CrazyNob wrote:I have updated the Gotek with Cortex Firmware and copied the selector.adf to the Stick.
no paypal anymore :
https://hxc2001.com/store/
CrazyNob
Post by CrazyNob »
For everyone who´s interested in the result.
It seems to be a problem with the Gotek Hardware, i have flashed an other Gotek and this one works perfect with the Amiga 500.
But its strange there's no problem on a CPC 464 with the faulty Gotek.
Thank you Jeff for the great support.
xadox
Post by xadox »
Jeff wrote:no paypal anymore :
Actually PayPal was also offered to me. While buying an additional license.
