CRC failuire and Read errors after new Firmwareflash
wollev45
Post by wollev45 »
hello
after the Firmwareupdate (actually version), i have (read) crc errors and bad blocks on my disks.
can´t load the workbench and other files from the sd card.
I have clear the settings in the menü and all settings switched to "config from HFE file"
a downgrade to version 1,6 fix the errors and the device is working with absolutely no errors. (same sd-card same files)
Anyone ?
Re: CRC failuire and Read errors after new Firmwareflash
Have you tried to reconvert your HFE files with the last hxc tool ?
wollev45
Post by wollev45 »
No, i have converted all my Files in 2011.
