Hi, can anyone confirm if it's working with a MKI or not ? I saw it's ok with the ASQ-10 but i'm not sure ASQ-10 and MPC60 are really the same.
Thx in advance
MPC60 MKI compatibility
Re: MPC60 MKI compatibility
This will work without problem.Mobus wrote:Hi, can anyone confirm if it's working with a MKI or not ? I saw it's ok with the ASQ-10 but i'm not sure ASQ-10 and MPC60 are really the same.
Thx in advance
Just installed the HxC F on the MPC 60 . The empty diskimages in the downloadsection need to be formated.
So save some time, here are some MPC 60 image files attached, already formated by the MPC 60.
- MPC60-FormatedDisks.zip
- (189.26 KiB) Downloaded 988 times
Thanks! I will replace the images by this one.12bitski wrote:Just installed the HxC F on the MPC 60 . The empty diskimages in the downloadsection need to be formated.
