First minutes with HXC & S950
kovshbeats
Hi! Connected the HXC into my s950. Formatted 32gb SDHC transcend card in FAT format. Copied HXCSDFE.CFG from Config>Default folder. Now powered on my s950 and when trying to save it says that disk is unprepared you must format it, when trying to format - "disk is write protected". HELP!!!
Jeff_HxC2001
Re: First minutes with HXC & S950
Download this :kovshbeats wrote:Hi! Connected the HXC into my s950. Formatted 32gb SDHC transcend card in FAT format. Copied HXCSDFE.CFG from Config>Default folder. Now powered on my s950 and when trying to save it says that disk is unprepared you must format it, when trying to format - "disk is write protected". HELP!!!
Unrar SDHxCFE_Akai_S950.rar to the root of your SDCard (in formatted in FAT32...).
Your SD is ready.
Don't forget to apply the resistor patch for the S950.
kovshbeats
Thanks for help. Done all of this actions (I asked lotharek to do this resistor mod when buying it on ebay because i dont know how to do it
Now when loaded this files to card i can see them. I choose empty_disk_000.hfe then when trying to save program i see - disk is unprepared you must format it. ???
Try this : remove the SD, enter the setting menu :kovshbeats wrote:Thanks for help. Done all of this actions (I asked lotharek to do this resistor mod when buying it on ebay because i dont know how to do it)
-> <Interface CFG> -> <S950 DD> -> <EXIT>
Reinsert your sd and retry.
kovshbeats
The same . Maybe resistor mod is not applied? How this will look when its applied? Sorry but im full dumb in all that technical stuff
A picture of theHxC please.kovshbeats wrote:The same . Maybe resistor mod is not applied? How this will look when its applied? Sorry but im full dumb in all that technical stuff
kovshbeats
Jeff wrote:A picture of theHxC please.kovshbeats wrote:The same . Maybe resistor mod is not applied? How this will look when its applied? Sorry but im full dumb in all that technical stuff
- IMG_2573[1].jpg (136.09 KiB) Viewed 16476 times
No jumper ? you need to put a jumper at the position ID0Akovshbeats wrote:Jeff wrote:A picture of theHxC please.kovshbeats wrote:The same . Maybe resistor mod is not applied? How this will look when its applied? Sorry but im full dumb in all that technical stuff
Also : did you see a resistor at the R12 placement (right down on the picture).
kovshbeats
Thanks Jeff, it works! Now im all into my s950 with Hxc! Thats crazy!!!
Please post an picture of the HxC installed into your S950kovshbeats wrote:Thanks Jeff, it works! Now im all into my s950 with Hxc! Thats crazy!!!
kovshbeats
Sure Jeff! Sorry for quality its the cell phone =)Jeff wrote:kovshbeats wrote:
- фотография.jpg (79.74 KiB) Viewed 16457 times
gclub
gclub
