Some Noob issues with my new HxC.
Retroman
Post by Retroman »
So I just got my HxC SD Floppy emu today.
At first it worked fine except I couldn't upgrade the firmware from 1.60 but eventually after trying a few SD cards it worked.
Now I'm running firmware V1_7_1_2 and every time I boot up on my Amiga 600 it doesn't load. It starts ok and displays the AUTOBOOT.hfe on the lcd but then it hangs and then the numbers run quickly up to 255 and it displays a "Direct Access: LBA 0000" and seems to cycle a bit up to 4000 and then just hangs, no errors on screen or lcd. If i press the middle button on the HxC it seens to start the process again.
Any ideas guys
Re: Some Noob issues with my new HxC.
Jumper setting ?
Retroman
Post by Retroman »
I got it working somehow. It might have been a dodgy SD card (8GB Class 10). Working fine now on a 8GB class 4.
Now I just need to figure out the best way to extend the LCD so I can mount it somewhere convenient. Any handy cables I can get or is it solder all the way with this thing?
