Middle Button Drive Select no longer works?
Balooga
Post by Balooga »
I just performed the firmware upgrade to v1.7.1.2. I can assign disks to Drive A and B within the Emulation Manager, and I can access both disks from the Amiga Workbench. But I can no longer change the disk in Drive B as Disk Drive Selector Menu no longer seems to work.
Previously holding the middle button would display the Disk Drive Selector Menu, allowing me to select Drive A/B.
- I have not changed the jumper settings which are still set to enable Drive A and B
- I have verified that DF1 is "on" in the Emulator Manager
- I have verified that "Disable Disk Drive Selector" is *not* checked.
In addition, I have also set "Drive B to On" in the new 'Embedded setting menu' (remove SDHC card and press/hold middle button).
Any thoughts on what might be causing this?
Thanks.
Re: Middle Button Drive Select no longer works?
The menu still there but you need to reselect an HFE to access it.
Balooga
Post by Balooga »
Jeff wrote:The menu still there but you need to reselect an HFE to access it.
Got it, thanks. But why the change?
