New HxC Floppy Emulator software for Windows and Mac OS X !
megar
Re: HxC Floppy Emulator v2.X.X.X
Post by megar »
The new "format" window, and the Visual view of the floppy are impressive !
megar wrote:The new "format" window, and the Visual view of the floppy are impressive !
Can be tried here :
https://hxc2001.com/download/floppy_driv ... 2_beta.zip (windows)
The pre-release of the new HxC Floppy Emulator software v2.0.3.0 is now available for Windows and Mac OS X :
-> https://hxc2001.com/download/floppy_driv ... 2_beta.zip
12bitski
Re: New HxC Floppy Emulator software for Windows and Mac OS
Post by 12bitski »
What will the Mac version be able to do? Will a USB drive work?
I just installed it and had a first look. Nice! :)
cweinberg
Post by cweinberg »
I like this very much! thank you. :)
now... when can we mount the floppy imgs from the MAC?
cheers!
i am working on this ! :D
New Software release ! :
14 July 2013: HxCFloppyEmulator 2.0.15.0
New Loader : SpeccyDos *.SDD support added
New Loader : Apple 2 DOS 3.3 (*.DO) & ProDOS (*.PO) raw file image added.
New Writer : HFE file with the HDDD A2 support for Apple II (http://www.bootzero.com/HDDD_A2_v1.2/HDDD_A2v1.2.html)
New Writer : Atari ST MSA file.
New Writer : TRS 80 *.JV3 file. (Done by David Barr ! Thanks to him :) )
New Writer : TRS 80 *.DMK file.
New Writer : PC88 *.D88 file.
FAT12 Loader/generator : Atari ST 902KB format corrected.
FAT12 Loader/generator : Atari ST 4.23MB format corrected.
HFE File Writer : Track padding function corrected.
EDE File Loader : edt & edv file support added, ASR 10 gap3 adjusted to 36.
JV3 File Loader : Sector interleaving correctly implemented.
IMD File Writer : No allocated sector issue corrected.
XDMS Lib : UTF8 path support added.
LIBSAP Lib : UTF8 path support added.
New Track/Sector support : GCR "6 and 2" Apple II DOS 3.3/ProDos.
FAT12 Disk Browser: Handle freeing corrected
Raw Loader - Predefined raw formats added :
- Roland W30/S330/W50/S50/S550 DD Floppy Disk.
- OS9 1280KB Floppy Disk.
- Linn/Forat 9000 Floppy Disk.
- KORG T3 3"5 HD Floppy Disk.
- Atari ST 3"5 DD Floppy Disk
- Standard 3"5 DOS ED Floppy Disk
- Special 2.5MB DOS EXHD Floppy Disk
- Special 4.5MB DOS EXHD Floppy Disk.
- Special 6.78MB DOS EXHD Floppy Disk.
Updated:
- Ensoniq EPS 3"5 HD Floppy Disk : Gap3 adjusted.
- Standard 3"5 DOS HD Floppy Disk : Gap3 adjusted.
- Standard 3"5 DOS DD Floppy Disk : Gap3 adjusted.
GUI - Drag & Drop Support : URI type path support added (Linux).
GUI - Track viewer window : New buttons to enable/disable track format analysis.
GUI - Log window : New buttons to enable/disable logs messages.
https://hxc2001.com/download/floppy_driv ... r_soft.zip
Download :
Note : All others software using the library libhxcfe have been updated too :
https://hxc2001.com/download/floppy_driv ... rowser.zip
https://hxc2001.com/download/floppy_driv ... fd_hxc.zip
https://hxc2001.com/download/floppy_driv ... us_HxC.zip
:D
GuybrushThreepwood
Post by GuybrushThreepwood »
Anyone else having issues with the new version 2.4.1.0 of the HxC Floppy Emulator software for MacOS Sierra? When attempting to convert an Amiga .ADF file to the .HFE format, using the batch converter process. The HxC Floppy Emulator software crashes.
Any resolution greatly appreciated :-)
have tried older software version ?
New version : HxCFloppyEmulator v2.1.6.0
22 January 2017: HxCFloppyEmulator 2.1.6.0
XML format definitions : Korg DSS1 DD disks added.
XML format definitions : Emax II disks added.
Command line tool : USB loader -> Raw loader added.
Amstrad DSK file added to the batch converter export list.
New Writer : Thomson *.FD writer.
Thomson *.FD loader fixed : Side 1 ID corrected to 0.
D88 Writer fixed : Cylinder and Side ID correctly set.
ImageDisk (*.IMD) export : Deleted data mark and data CRC error flags supported.
FAT12/16 Disk browser : Entries First cluster readback corrected. (With high word uninitialized).
IMG loader : More disk sizes support added.
DosDiskBrowser : 1.743MB & 1.764MB added.
64bits systems : Batch converter and Dos Disk browser issues fixed.
MacOS X & Linux version : file export -> Auto-append the file extension.
Track editor : Disk flux stream reverse function.
Track viewer & editor : GUI layout changed/updated.
TFM
Post by TFM »
Thank's for the update! Awesome new functions! Great!!! :D
analogreek
Post by analogreek »
I'm on Mac OS X El Capitan, using v.2.1.6.0 and I'm getting this message, when trying to access the USB settings:
»FTDI Driver D2XX Not Installed!«
What to do?
(I have a USB Gotek Drive and I'm trying to use it with a Yamaha SY99 synthesizer)
Bildschirmfoto 2017-05-25 um 14.23.16.png (133.04 KiB) Viewed 101766 times
analogreek wrote:I'm on Mac OS X El Capitan, using v.2.1.6.0 and I'm getting this message, when trying to access the USB settings:
What to do?
This is for another hardware. You must use the SD settings window.
New version : HxCFloppyEmulator v2.1.8.0
21 January 2018: HxCFloppyEmulator 2.1.8.0
New Loader : Atari ATR file image loader.
New Write & Loader : HFE V3 : variable bitrate and other proctections support.
                     (Experimental ! The file format definition is not yet finished !)
Kryoflux raw files Writer : Fix dead lock with tracks without pulse.
Amiga DOS image browser : 85 tracks AmigaDos image support.
Disk Image browser (FAT & AmigaDOS) : Fix null-sized file import issue.
Disk Image browser (FAT & AmigaDOS) : Can now delete folders.
All image loaders : Fix possible track skew calculation error.
Emax image loader : GAP fixed to 30.
Thomson *.FD loader : Sector interleave set to 7
Command line tool : -uselayout option can be now used to specify external xml disk layout file.
