Roland S-330 Problems
chaworth
Post by chaworth »
I purchased an HxC SD card emulator to use in my Roland S-330 based on the account that this combination has worked. However, I have so far wasted 4 hours today trying to get this thing to work.
I am using a Sandisk 2Gb SD card (brand new), which I have formatted as FAT32 in Vista. I have transferred the HXCDFE config file onto the card and have converted a single S-330 OS image that I took using S-Disk for windows, renamed as a .IMG file, and then converted to an HFE file. I can see all of this in Windows.
I have then set the HxC up in the S-330, with the data cable set pin1 to pin1, but every time I boot the machine, all I get is the 'Reading FAT...' message.
I have tried this for all ID jumper settings on the PCB, all with the same results.
Is this board actually compatible with the S-330 and if so, what could I be doing wrong?
Regards,
Chris.
Re: Roland S-330 Problems
SDCard compatibility problem. This will be corrected in the next firmware.
Have you another sdcard to try ?
There are some missing info:
->Revision of the Emulator ? (C or F ?)
->When did you purchase the emulator ?
-> Actual firmware version ? (printed on the LCD without sdcard).
chaworth
Post by chaworth »
I don't have another SD card to try - I bought this one especially for this application (thinking Sandisk would be widely supported).
Missing info:
->Revision of the Emulator ? (C or F ?) Rev F 3.5" enclosure
->When did you purchase the emulator ? This arrived 2 days ago.
-> Actual firmware version ? (printed on the LCD without sdcard) It states it is a Revision C board at 1.6.0.0
chaworth wrote:Hi,
Missing info:
Ok so i will send you right now a new firmware by email.
