copying disk image to floppy
jata1976
Post by jata1976 »
Hi everybody,
I have a simple question regarding SP1200 sample exchange with a friend, who hasn't got the floppy emulator.
If I use the floppy emulator with my SP1200 and I save all my work on that SD card, would I be able to copy back these SP1200 floppy disk image files to a real, physical floppy disk and use it with another SP1200?
So, is there a tool that does it in a straight forward way? Is it compatible with a simple USB floppy drive or I need a special floppy drive in a desktop PC?
Re: copying disk image to floppy
jata1976 wrote:Hi everybody,
Actually the only hardware able to this is the KryoFlux. (http://kryoflux.com/)
The other possibilty is to plug an floppy disk drive + the HxC on the same SP1200 and play with the jumpers exchange the drives during the copy :
http://www.youtube.com/watch?v=RRedfoBSkTg
http://www.youtube.com/watch?v=AVfzvnjUlyw&feature=plcp
jata1976
Post by jata1976 »
Thank you for the fast reply Jeff, I really appreciate it.
So, it means i have to spend money again... :)
I don't know if you use the Kryoflux drive, just wondering how straight forward the operation.
In the ideal case I would just need to copy those floppy image files to my PC from the SD card I use with the HxC floppy emulator and then open them with the Kryoflux's software and use a blank floppy and it will do the job without any hassle.
Is the HxC floppy emulator's and Kryoflux's floopy image formats are compatible with each other?
