Write-Protected Disks
mojorific
Post by mojorific »
Hi HXC guys!
I've been having a great time using my HXC SD Card emulator.
Unfortunately though, still have an issue that I don't understand how to solve.
Some games indicate that my disks are write protected and cannot be written to (for save games).
Is there a way to enable/disable write protection on HFE files? Or is this something that I have to do when the disk is still an ADF file before I convert it?
Because they are virtual disks, I'm not sure how to fix this.
Re: Write-Protected Disks
mojorific wrote:Hi HXC guys!
Check the SDCard write protect lock switch.
What is your HxC Revision ? Do you have the last firmware.
mojorific
Post by mojorific »
That is exactly what it was. I have several SD cards, and somehow some of the write-protect switches were moved. Funny my PC USB adapter doesn't seem to care whether the SD card is in write-protect mode or not.
Thanks for the reply.
