Auto boot problem
Beaps
Auto boot problem
Post by Beaps »
I have an Amiga 600 & when I run the autoboot file the HxC program loads but nothing else happens.
It does not read the drive?
It says just the press Help button etc
Any Ideas?
Beaps
Re: Auto boot problem
Post by Beaps »
Any one help me out? :?
NTSC Amiga ?
HxC on DF1 ?
Jumper config ?
Floppy Cable used ?
HxC Firmware used ?
Kickstart Version ?
Beaps
Post by Beaps »
NTSC Amiga ? Pal
HxC on DF1 ? HxC DF0
Jumper config ? bottom right
Floppy Cable used ? original Amiga one
HxC Firmware used ? Not been updated in last 8 months
Kickstart Version ? 2.1
Beaps
Post by Beaps »
I'm also using a micro SD 8gb in a SD caddy if that helps?
Can you take a screenshot ?
Beaps
Post by Beaps »
Sure, even better I will do a quick video.
Beaps
Post by Beaps »
here you go...
I hope you can help me out :D
http://www.youtube.com/watch?v=iiXroCvzA4k&feature=plcp
Just a thought, do the files have to be in a folder on the SD card or in the route?
Beaps wrote:here you go...
Ok i see : your jumper setting is complety wrong :
Page 9 : https://hxc2001.com/floppy_drive_emulat ... Manual.pdf
Use the ID0-Drive A setting.
Beaps
Post by Beaps »
:lol: simple as that, changed the jumper, jobs a good one
THANKS!!!
Beaps wrote::lol: simple as that, changed the jumper, jobs a good one
THANKS!!!
Don't forget to update the youtube video ;)
Beaps
Post by Beaps »
hahaha will do THANKS!
