Copying text files to SD card directly from PC
djm
Post by djm »
I want a simple way of copying text files from a PC with an SD card writer to use in the Floppy emulator which is used on a CNC.
Re: Copying text files to SD card directly from PC
djm wrote:I want a simple way of copying text files from a PC with an SD card writer to use in the Floppy emulator which is used on a CNC.
If your CNC use an MSDOS compatible disk you can use this :
https://hxc2001.com/floppy_drive_emulat ... fd_hxc.zip
Once you have intalled this driver, just double click on the HFE file and open the virtual drive A: or B:
What is your CNC ?
