AKAI S5000 - S6000 ?
wintersun
Post by wintersun »
Seeing as the 5000 and 6000 has a floppy drive, is it supported by the HxC ?
Re: AKAI S5000 - S6000 ?
wintersun wrote:Seeing as the 5000 and 6000 has a floppy drive, is it supported by the HxC ?
Yes it should work without problem.
shiroiyuki
Post by shiroiyuki »
does anyone have a image of a S6000 bootdisk, or can point me to a tool that can read and convert the disk to a image?
Kind regards,
Sascha
teevee
Post by teevee »
shiroiyuki wrote:Hello,
Kind regards,
Sascha
Hi Sascha,
You can download the OS (2.14) here:
http://www.akaipro.com/product/s6000#downloads
shiroiyuki
Thank you very much! :D
Zouzou85
Post by Zouzou85 »
I just bought an Akai S5000.
I want to change the floppy disk drive to a USB drive.
I can only find information about the Nalbantov USB drive, which is very expensive!
Is it possible to install a Gotek player on an S5000?
If yes, which model is suitable?
Do I have to program software or something else to run the Gotek player? (I am a neophite ...)
If the Gotek is not compatible, what are the other solutions ...?
In advance, thank you for your help !!!
