HxC REV C Direct Access Crashed
danko
Post by danko »
Hello, my HxC installed on my Amiga 600,crashes when loading file AUTOBOOT.HFE the display shows "DIRECT ACCESS" It does not allow me to use the switches to select the file to load before it worked, I can not understand what happened .. .
Re: HxC REV C Direct Access Crashed
danko wrote:... shows "DIRECT ACCESS" It does not allow me to use the switches to select the file to load before it worked, I can not capiere what happened .. .
This is normal : you must select the files on the amiga !
