External Button A600
danko
Post by danko »
Hi, everyone I am a new user just registered, i received days ago the HxC Floppy Drive Emulator, I want to install it internally on the Amiga 600, I just do not know how to connect the 3 button (Previous,Eject/Select and Next) on the floppy drive emulator, there is a wiring diagram to know how to connect them? here are some picture that I found online of what I make on my A600,
just that the pictures can not understand how they were connected.
https://lh4.googleusercontent.com/-YFPW ... k_0452.jpg
https://lh5.googleusercontent.com/-1nbU ... k_0451.jpg
https://lh3.googleusercontent.com/-VPnj ... k_0445.jpg
N-Ed
Re: External Button A600
Post by N-Ed »
Pin 1 should be connected to all the extra buttons, then follow the pinout in page 26(7.3 User interface) of https://hxc2001.com/floppy_drive_emulat ... Manual.pdf. Does this make sense to you? Haven't got around to doing this on my 1200 yet though... So somebody else can please correct me if I'm totally wrong here!
danko
Post by danko »
Yes, I so want to do well, to put the 3 buttons on the A600 outside case, are here but no one helps you ....... I want to play it safe on soldering the wires.
danko
Post by danko »
N-Ed wrote:Pin 1 should be connected to all the extra buttons, then follow the pinout in page 26(7.3 User interface) of https://hxc2001.com/floppy_drive_emulat ... Manual.pdf. Does this make sense to you? Haven't got around to doing this on my 1200 yet though... So somebody else can please correct me if I'm totally wrong here!
Hi,pdf file does not specify what is required, are you sure that that page?
Yes. As N-Ed said :
N-Ed wrote: Pin 1 should be connected to all the extra buttons, then follow the pinout in page 26(7.3 User interface) of https://hxc2001.com/floppy_drive_emulat ... Manual.pdf
1 - VSS (Common to all push button)
7 - BUTTON_DOWN
9 - BUTTON_UP
8 - BUTTON_SELECT
danko
Post by danko »
7 - BUTTON_DOWN
9 - BUTTON_UP
8 - BUTTON_SELECT
Ok,there are 2 types of contact of Miniature Push Button Switch PTM (push to make) and PTB (push to break), what you need?
The classical : Push Button Switch PTM (push to make)
N-Ed
Post by N-Ed »
Yay, this is like the first time I actually understood what needed to be done solder wise to make something work hehe :wink:
Now I just have to be brave and start cutting into my beloved A1200 case, that's way more scary than doing the soldering :cry:
N-Ed wrote:Yay, this is like the first time I actually understood what needed to be done solder wise to make something work hehe :wink:
other possible choice : cutting nothing and just use the file selector :wink:
N-Ed
Post by N-Ed »
Yes but using the buttons is easier in my setup, never really liked the software file selector. <-- But I like that it's at least an option, this gear is great. Best new gear for my Amiga, next to the brand spanking new Indivision AGA MK2 that is :mrgreen:
When I'm all done installing this I will make a really easy to follow instruction on how to do this to a Amiga 1200, might be a good sticky here at the forum!
